1995 Indigo Lights/Black LSC Progress
Chris, your "fleet" is incomparable. The addition of a stick shifted Coyote blows my admittedly weak brain. Keep us posted. I live my Mark dream alter-ego through you.
2017-08-21 20.11.43 by Chris, on Flickr
looks clean in here. engine has a touch under 100k.
2017-08-21 20.56.38 by Chris, on Flickr
got some Boundary billet gears to put in the oil pump.
2017-08-21 20.53.31 by Chris, on Flickr
the housing and stock gears.
2017-08-21 20.44.41 by Chris, on Flickr
going to learn how to time it tomorrow.
I decided to replace the chain guides because they aren't that expensive.
they are on order.
Hi Chris this is Michael dad just walking on the key board an checking on what happening. We are working on a special deal that is keeping us busy. fire Mike a email to find out about it. security that he imposed. Hope things go good for you the old man JD.
went and got me a place to work on it.
44056813_1114475902064114_7355363542893068288_n by Chris, on Flickr
trimmed turbo chucks fit nicely on the coyote block.
2018-10-12 18.35.34 by Chris, on Flickr
bolts right on.
2018-10-12 20.12.44 by Chris, on Flickr
shiny new oil pan.
2018-10-19 17.33.38 by Chris, on Flickr
lots of trimming and the engine mounts to the subframe.
2018-10-19 21.03.13 by Chris, on Flickr
i'm slacking on updates, but hope to do more soon.
the engine is sitting in the car now, but there is still much to do.
i got the wheels and tires mounted for it the other day, as well as acquired my 14" front brake kit for the car.
i'll try to get some more photos uploaded soon.
?user_id=72496829&webp=true&sig=6d16700dabe3f1e7f52902b1c5e22c200c2d761fbed27f4cb885f0b9e64168ed.jpg
update.
not a ton has happened.
when i had time, i didnt have money.
now i have some money, doesn't seem like i have the time..
anyway, excuses aside.
the motor is actually in the car now. not for good, i needed to test fit to be sure it would fit.
subframe will need to come back out for powdercoat and bracing.
these are brakes i have for it.
V calipers and gt500 rotors. the eagle eyed among us may remember them being on lobirds car.
a shot of the sump on the aftermarket pan.
i raised the engine a half inch to clear the pan DLF style.
3 core radiator for the car. a sneak peak of the cai that came with the engine.
an mt82, a 3650, and a 4r70 in the back.
mt82 with a barton shifter for this car. 6060 when i break that.
the modded spindles and the coyote fuel tank.
plan is to convert the mark tank to returnless, and wire the coyote fpdm to run a new fuel pump in the mark tank.
my intake and stack of clutches. i have too much stuff in here.
some of my other plans include converting to an electric steering pump so i dont need to mount a pump on the engine.
going to to try to reuse the mark ac compressor and lines, someone makes a kit. and use the coyote alternator. we'll see how that goes.
also looking into some long tube options. something that will clear the steering shaft.
need to get back at this. been too long.
Didn't realize you ended up with Alans Cadillac V calipers. It was a while back, when I went to his house and he was able to show me how he was able to make those fit his Mark VIII. Just amazed how much mechanical talent he and others like you have done with our cars.
Can't wait to see more update photos.
no new pics because everything looks the same but...
ordered a driveshaft, should be built soon.
put the clutch master in with some braided line and AN adapters, clutch seems to work but hard to tell until i have a driveshaft.
mt82 has a pretty deep 1st gear so i have a 3.08 track lock pumpkin to start off and will adjust by feel later.
got some coolant hoses figured out and was able to get the engine up to operating temp. tstat and fan work and it has oil pressure.
all looking good.
car is mobile under its own power now.
brakes still squishy, not sure what's up there.
installed a volvo electric power steering pump.
probably gonna move the battery to the trunk.
not sure the hood is gonna clear.
lots of little things left to do but its cool that I don't have to push anymore.
few more updates. built some exhaust. kooks mid length headers into cats and an x pipe, and followed by some valved mufflers and quad tips. i am not a welder so don't look too close.
will the hood close? i'm not sure, but i kind of doubt it.
the electric steering pump and speedo are run by gps now.
I also installed and wired a stock mark viii temp sender and oil pressure switch on the coyote so the dash continues to operate as if the 4.6 is still there.
moved the battery to the trunk. abs and traction control continue to work. i do have lsc lights for it but these halogen ones will do for now.
almost time for more paint.
out and about last night. i have a blue hood for it, need to swap that out. rest to be painted soon ish hopefully.
drives pretty good. will need tires and an alignment though.
the coyote control pack has a weird stalling issue when coming to a stop and pushing in the clutch that i need to fix. starts right up after.
googling says its related to either the lack of a vss input to the pcm, or the lack of a clutch switch input, or both.
either way, i'll figure that out.
The rear fell off today.
A few weeks ago someone asked, are there no quality parts left for this platform out there?
And for the most part, no, there isn't. Hoard things people, the end is near.
Same retailer, same part number. One is the oe style adjustable bushing, right, one is the gross aftermarket style, left.
