billcu
I've got 2 gen 1's and 2 gen 2's. They are all great cars and they are all different.
I still like the gen 1's styling better though.
I still like the gen 1's styling better though.![]()
I think that video header might be a little mixed up. Appears to be a Gen 2 you're in, not a 93.![]()
It actually looks like a 95 or 96.
Notice the Lincoln emblem on the Radio bezel and no dash ignition.
The compass sensor in a Gen2 is that thing that hangs under the mirror
I own both a 97 and a 93 with the updated interior. Honestly, if you want a car that has all the features of a new car such as digital odometer and OBDII and plan on keeping your car stock get a Gen II easy. If you're not much into modding or customizing your car get the Gen II. But if you plan on keeping your car and personalizing it, it doesn't really matter which you pick. Go for which body style you like better. IMO if you look at keVIIIn's sig that Gen I has an aggressive look yet elegant and just looks more intimidating (minus the mudflaps no offence). The tail end also looks more like a hot rod in the Gen I and prefer it over the Gen II now. I plan on getting the seats redone later on for both cars so I doesn't matter which is better for me and plus I plan on getting Gen II door panels on my Gen I. Otherwise it looks the same except I have two ash trays in the back. The multi control for wipers is much better on the Gen II. I also have Gen II side mirror and plan to hook up the puddle lamps and led turn signals soon when I'm in the process of replacing the door panel. Gen I also have a light key ring on the outside of the door handle which looks nice. Driving wise the steering response is much better in the Gen I vs the Gen II because of the lower ratio. The steering feels more responsive and precise in the Gen I. Night time driving is the same in my LSC housing vs my Gen II. It has an identical layout on the ground. So again if you plan on modifying and customizing it all depends on which body style you like better. That's all I can think of for now. Also, I plan on removing the exterior antenna with an interior one so I don't have to worry about that. But honestly stock for stock the Gen II give a much better impression and much better feel. But a well taken care of Gen I looks better IMO. Here is my Gen I as of right now. Ride in a 93 Lincoln Mark VIII - YouTube
BTW Gen I also has wood trim but with a nice Lincoln logo but only enough room for one drink. Plus I have noticed better highway mileage out of the Gen I. Last time we drove together at 80 the Gen II got a 25MPG vs 27MPG in the Gen I. I also squeezed out 29 going 75 in the same trip different time. This is using a full tank of gas and dividing the miles it has done by the gallons I put in the next fill up so it's not computer error. Long response and hope that covers it. I love the gadgets like the power steering tilt/scope but rarely end up using it. Oh and the key hole in the Gen II is in a much nicer location, even though it gets scratched up, than the Gen I which is in a dated place.
Well, he did say "93 with updated interior" so, maybe it is and the dash has been swapped out and the rear view mirror was replaced with one that has the digital readout. Yeah, I noticed the dash ignition wasn't there and honestly didn't think about the Lincoln emblem on the stereo bezel. It sounds good though. Kinda the sound I'm after when I do the exhaust. Looking like Spring, if I don't get it done by mid Fall.
The sound is nice but I personally am over it if I can't find a way to fix the drone. If I do find a way the sound for the exhaust is fantastic.
Yup the credit goes to GMAN since it's his older car and he swapped out the dash. The rear view mirror does add a nice appeal inside the car. The mirror as Mark0101 said is not from a 98 Mark VIII. Just look for any Cadillac in the junk yard around the 1998-2006 range and it should have a digital read out compass with the auto/off buttons for dimming. There were a couple Sevilles and Devilles that were in the junk yard and it was easy pickings. I replaced it on both my Gen I and Gen II. However since the compass reading for the gen II is on the mirror, originally, the compass readout in the dash isn't correct. You might be able to get both of them to work but i'm not sure. Also, the plugin connection is easy to do for the swap. Oh I forgot to add in one other thing Gen I have Gen II don't. Two sun visors for each passenger in the front... oh yeah! And btw does anyone know if the controller for the wipers in the steering column is interchangeable between Gen I and Gen II?
