racecougar
If WOT AFR is indeed at 12.5:1, you're definitely leaving power on the table there.
..not sure where the extra 5lbs came from?
Does this mean it will run even more rich in the cool of spring?
Cause this is a drag car why not put mustang breaks up front it will be less rotating mass and the calipers are lighter
I also happen to have some for sale.
But the brakes don't move with wheel so there won't be any difference in the rotating mass.
The ROTor does.. and a cobra rotor would be more
