SATURN5
Dr. Frankenstang
Building a rear upper shock mount brace....
Nice work but those angle irons are gonna flex without angle braces...but what do i know im just a fabrication specialist
How is that suppose to keep the shock towers from flexing?
I suppose it would work like a panhard rod.
Ren
Maybe if the square stock was located higher on the angle irons and wasn't welded as well, I could see that happening, but since he's got the square stock down low, and welded good (And I know Bob, its not gonna budge)
Its easier to push over a post at the top, instead of down where it is sank in the ground, right?![]()
Well, lowest point is best but not like the mark is gonna flex anyway...the shocks are dead vertical with no angles to them to push the quarter frame inwards like most cars
really this thing is pretty pointless and jsut for looks. in order for the the shock towers to flex you would have to be having some major malfunction of the inner structure of the car. there really isnt much force coming up threw those shocks. plus most unibodies use a strut brace witch is in fact way more usefull than this as all the waight of the car is transferd threw the strut towers unlike the mark viii because it has the bag or spring in some cases right under the frame rail. so all the forces of the suspension are going up the the framerail not he shock tower.
A crooked inset licence plate holder is pointless too. Oh snap I went there.(just kiddin)
