But you are not having temp issues from running at max power levels, you are having them from just cruising around, no? To me it seems it should not matter how much HP that thing is making cause it aint making it at 45 MPH in 4th gear.
You have a larger then stock radiator, no? With the multiple fans you should have more CFM then a stock Mark too. There is NO reason for the car to be running as hot as it is unless:
1. Severe air flow restriction. Prolly not though because of the fans total CFM.
2. Too much timing at low loads.
3. Running lean. What is your A/F at normal cruise?
4. Water pump is not functioning properly. (Cobra pumps designed for higher RPM plus they have a smaller pulley so with a Mark pulley its spining way too slow)
5. Cracked block/heads/gasket. Not likely cause you say it does not spit out any coolant.
The car is just too damn hot and I hate to see such a fine ass ride having issues like this. It has to be something simple. If my old Mark with a completly stock cooling system and underdrive crank also pushing a non-intercooled positive displacement supercharger can run 208* all day long in traffic then thats why I keep thinking water pump.
