Lownslowlsc
Well on the way home from work as soon as i put the heat on it turns on/off for acouple secs then stays off. I have water on the pass side floorboard. Water has leaked down before but not to the point where it effcts the b/m. So more then likely a lower w/s leak that got onto the connecter for the blower..Thats fine and will check the connecter in a bit.
When i first got it i took the cowl off and re sealed the air duct so that cant be were its getting in.
Is there something i can use to help seal the lower w/s weather stripping as to not let water in? That the only other place it could come through at..
