when we are not in the garage we are in front of you looking at you in our rear view mirror.
So would you like to run me then?when we are not in the garage we are in front of you looking at you in our rear view mirror.
So would you like to run me then?![]()
the mans mark is the one that scrapes knuckles when you need to change an iac or the tps.
gen ones are boys marks the man's mark is the gen 2, because we are getting older and dont have the spunk to play repair games all day, we just get to turn the key and drive in style, you guys get to stand in the garage and bitch about fxing everything on them dinosaur's
sounds like he does:shifty:
rather embarrass the guys on the other side of the aisle then one of my brethern on this side.
Seems like the Gen 2 has two wiring harnesses on it where the Gen 1 only has one and something else about the size I think. I could be wrong but seems like there is some kind of difference. I do know that on a Gen 2, if you were to put a Focus pump on, the wires have to be reversed where on the Gen 1, they wouldn't. Something must be different for that to be an issue.
Gen 1 pump OEM
Gen 2 pump, obviously not OEM but Bosch also has two harnesses on it.
Here is the Gen 2 Bosch. Above is a Carter.
Taking about putting a Gen II motor and trans in a Gen ISame as a Gen1
