BAD97LSC
so i go out in the garage to smoke a cigarette and i said to my wife why does my car look like its leaning, i go to the pass side and see the rear tire is flat WTF. my driveway is a slope not the kind you want to jack a car up on, so i blocked the front tires and put the e-brake on and only jacked up the right rear enuff to get the tire off. there was nothing stuck in it, but i did see a hole, when i put my tire reamer in the hole and moved it around i couldnt get the air to leak so i jumped in petes mark and took my wheel to the shop. i was able to push my reamer through the hole by hand so i assume thats where the leak was who knows. put a plug in it and threw it back on the car. i swear its from work one of the dicks at work is like a little :q:q:q:qing kid and shoots nails and screws and :q:q:q:q out of the shop towards the road with his air line all the time, this is the 3rd time i had a leak in my rear tires directly after leaving work. the next time i see him doing it i am gonna take his rear lug nuts off his dakota and let him leave like that. some people need the :q:q:q:q kicked out of them.
