97 lsc converted hids 2 years ago have always had problems with the passenger side messed with the wiring on that side and couldnt get it to work,so i get the bright idea to rewire the passenger side to the drivers side thinking that the wiring should be all the same but evidently it is not! both work for a few seconds then blinked out , then crap hit the fan. all interior lights went nuts i think from unhooked wire to the lights? so i cut it all back out stripped wire off on passenger side and rewired that side back up , got it to work but drivers side will not work at all unless i plug passenger side into ballast then it works . also now headlights do not shut off with the switch at all turn it either way doesnt show delay or shut . is it possible i blew out my switch ? is there separate modules? for each side? i could find any fuses for any of this stuff . what am i missing ?
