GMAN
OK everyone give me some solutions that will permantly fix a P174 Bank 1 Lean code? What are all possibilities that will make this code come on?
Well, I can rule out manifold leaks, be the whole top end was done before I bought the car. I thought about the MAF, taking it off and cleaning it. I will also look into replacing the O2 sensors as well. Which o2 sensor would be the one to look at?
dont ever say the work was just done so i can rule this out, that doesnt mean squat, we are human, and we do make mistakes, for all you know the person who went through the top of the motor could have been a crackhead. just because someone is a mechanic, and owns a repair shop, doesnt mean they are god! check everything that was suggested, i'll put money on whatever was recently done is the problem!
Terry, those would only be the culprit if he had P0171 and P0174. MAF would throw a code for MAF (maybe) or the car would idle rough or both banks would read lean.I'm going to take a guess here and say, swap out the MAF with another one you have and clean it good with MAF cleaner and install it. Disconnect the battery first and then connect back when done and see if you still have that code.
Could be EGR related too.
+1Since he only has 1 code, the problem has to be local to the passenger side. The only other option would be a bad O2 sensor. He would need to see the actuall switching, to determine this. Also, ecm codes on OBDII vehicles cannot be erased by disconnecting the battery. They can only be cleared by scan tool.
It will be the front one on the drivers side.
I know he said bank 1 but isnt p0174/p174 supposed to be bank 2?I'm pretty sure that Bank 1 is the passenger side.
