I stand corrected, I see Jamie and a couple others said Moog. Personally I like OEM style as do many others on here. I bought Moogs before but had them wear fast cause my car was lowered and I drive it hard. With the straight ones I haven't had any issues.
So my bad, I guess it was only me and Sapperfire saying not to get the bent style. And it is well known that we both know jack chit about these cars. How we got my new motor to run is beyond me.
As to the ebay crap. YOU were told as well as many others. If you had the slightest clue how to use the search function then you would know what to do and how to do it and what to use.
You see when I first started here and knew very little about these cars I was told to use the search function. I did. I learned SOOOOOOOOO much about these cars its insane. I also learned how to fix it right the first time. If its something new and I cant find all the info by searching then I ask. I pay attention to when people are giving me sound advice and I follow it and it gets fixed.
I have NEVER swapped a piston engine before and I chose the holy grail of PITA engines to swap for the first time. But following sound advice and doing some research I did it. I didn't come on here saying "Its in but wont start", no, I just did the proper steps that I found on here to figure out why and I fixed it.
Point is you made 15 worthless threads about BS that would have been easily fixed and answered had you just searched for it. You would have known what to use and not use and how to swap it.
As to the comment of me not taking advice....... you're an idiot. I take advice thats proper and disregard the obvious dumb chit. Unfortunately as late there are many people on here that give just terrible advice that makes no sense.
Here are just a few screen names that will give you PROPER advice:
BAD97LSC
Sapperfire
LaserSVT
DLF
Kustomizingkid
Stack
Ford Nut
MRZEE
LSC HUNTER
Dan
Chicken
Mespoc
ONEBADMK8
There are a couple others too but if you follow those peoples advice then you will have a good running car.
If you are a true car enthusiast then you will listen and learn. Do some research and learn about the car and its quirks/fixes. If you do not want/cant do that then you should sell the car and get a Civic. It will never break and you wont have to fix it.... plus they are disposable.
BTW, if you were within 200 miles of me you would have that tissue box shoved so far up your ass you could taste the cardboard.
