I have also had bad issues with the knock sensor pulling 6* timing after 4100 rpm. Car would command 28* and then the knock sensore would pull as much as it could and there was still detonation. I pulled out 6* all together but still saw a 3* knock sensor pull around 4400 -5200 RPM but it still pulled .25* by shifting points.
I then realized I misscalculated my fuel curve and when I thought I was adding fuel from 4K up I was actually pulling fuel.
I just remapped it and added enough fuel for a calculated 12.49 AFR after 4K and about 12.7 from 2800-3900 all under WOT runs. That doesnt meen thats what it will run but since I did have it set for 13.0 from 4K on I bet that was my detonation issue.
Will data log tomorrow and see if it worked.
