94m5
Dmaup's Daddy
The title obviously got your attention because your reading this.
What I am about to send off for machining is a custom intake manifold to adapt an Eaton M112 to a B-head intake pattern. Where the Kenne-Bell setup retains the IMRC's, this replaces the whole damned thing. I'll have to modify the snout of the S/C to line up with the VIII belt system, but that's a small issue. I have already converted my VIII to an 8-rib belt system (courtesy of my 99 V10 F250), and hope that with a double tensioner I'll have no slippage issues.
It'll be run on my 150K mile long block at around 9-10 PSI, with methanol keeping it cool under boost. The nice thing about using the Eaton bolt pattern, is upgradability to whipple later on down the road.
Anyway, this is the preliminary design. I'm having it machined out of ABS plastic for mocking up everything, and once everything is right, T6061-T6 will be the final material.
[captianjacksparrow]What say you?[/captianjacksparrow]
