topher5150
so i put the underdrive pulley set had to take the radiator hose off topped it back off and now it's running rather warm, is this normal what should id do
I use a large funnel that fits into the Xtube, the funnel holds about a quart..
I keep the funnel about 3/4 full and that creates an expansion tank above the xtube, running the car at idle will remove alot of air.. as it will go up into the expansion area rather than circulating back thru the system.
