joegr
...What website did you guys end up going with for the cheapest OEM parts?
Thanks any advice would be great.
Ford Parts - Genuine OEM Ford Parts & Accessories Online
Genuine Factory OEM Parts & Accessories | TascaParts.com
(Part Number) (PNC)
* "HR1" / "707299-S300" (*top* O-ring for the 9N499 to 8548A)
* "8255B" / "4Z-8255-CA" (*bottom* O-ring for the 9N499 to engine block)
* "8255A" / "JV-8255-CB" (The 2 O-rings from 8548A to front face of engine block)
* "8590" / "9Z-8590-AB" (Large O-ring from 8548A to 8592)
* "9439" / "9Z-9439-AA" (Intake Manifold Gasket)
The 4 parts listed above are the various O-rings (gaskets/seals) that are contained within/between the 3 cooling plastic components (8548A, 94N99, and 8592).
front of the plastic side tank on the passenger side. You may need to remove the upper radiator mount on that side to see it well enough. Here's a picture of the front of the radiator with the surface of concern circled in red.
...Other quick question: IN manifold is going to be removed without taking out fuel rails. Is there an easy way to get the fuel line connecting both rails off without chomping up that fuel hose? (it goes over and across the manifold).
Also, not going to remove throttle body, don't know of advantage to that.
What is the part number for the damn Bleeder hose that connects to part 3W4Z-8C289-AA...I just need it
...So, please confirm my suspicions: the OEM degas bottle (Motorcraft 5W4Z8A080AA) does not come with a cap, correct?...
...The bottle cap part number is one of these, from what I gather: 9C3Z8101B, 1W138101AA, F6DZ8100A, RS103, RS527
Looks like the current number is : F6DZ-8100-A
F6DZ-8100-A - Ford Parts Giant
Wow, it's come down to a reasonable price. It was much higher before. They seem to last a long time and when they were more expensive it didn't make much sense to change them. Now, it's probably worth while.
so that's why I put that number first. Is there another way to tell?Replaced By 9C3Z-8101-B
It has usually been one to two weeks for me, but that’s usually at Ford Parts Giant. That said, LS parts are getting harder to get. I may start ordering from Jaguar. They sell many of the cooling parts in kits. Most should fit.
What kinda of changes need to be made to work?Here's one example, but it will take some modification to be able to use it.
www.amazon.com/dp/B008A1C3T2/?coliid=IC6FUWY0QIK7E&colid=1O8V1F5VGF8TU&psc=0&ref_=lv_ov_lig_dp_it
