RigsLS
- Joined
- Mar 10, 2012
- Messages
- 7,734
- Reaction score
- 523
... can I just remove my cats and sensors period?
No!
The upstream O[SUB]2[/SUB] sensors send readings to the PCM to aid in adjusting air/fuel mixture. They help determine, in real time, if your air/fuel ratio is rich or lean. They do not directly measure the air or the fuel entering the engine but when information from oxygen sensors is coupled with information from other sources, it can be used to indirectly determine the air/fuel ratio.
The downstream sensors need to send a particular voltage reading around .5 volts constant, within a range that is acceptable, if outside of range, it will throw P0430 and P0420 instructing the PCM that the exhaust emissions are out of wack and not acceptable. In turn it will then make attempts to adjust further fuel trim and here is where your problems begin.
It's not going to work by just removing the CATs completely and zip tying the Oxygen sensors out of the way. The Engine is not going to know what to do with itself. Sure you may go a little faster on the quarter mile for a while but engine damage is surely guaranteed.
To do it properly, you would 'gut' a CAT ... as it's termed.
Hollow it out. The Upstream sensor stays put, continues to monitor the exhaust and is able to (EDIT) 'participate in altering' fuel trim as needed. Downstream sensors can either be removed and plugged or simply leave the sensor in with a disconnect at the electrical. However ... a tune is then loaded where the value on the downstream sensors for both banks are hard coded for the correct voltage reading the PCM wants to see. Usually the .5volts depending on make/model. This is known as 'Zeroing out'. It will now always read the correct voltage and thereby fools the PCM that the converters are doing their emissions functionality. As in ... we're all good on the downstream emission, no need to adjust. No CEL, Fuel millage remains.
Please note during Wide Open Throttle, this closed loop o2 sensor reading system is momentarily disabled by default. It will not attempt to make any adjustments.
Beside the part where without CAT's you are going to be driving obnoxiously around town, there is the little part of dumping contaminated crap into the environment that you and I and others need to breath in order to remain somewhat healthy. You're going to have problems passing emissions testing, thus no tags.
It's also illegal and comes with a hefty fine I'm sure. You thought it was fun getting into handcuffs trying to break into your own LS, wait till you see what they'll want to do to you when you get pulled over because of the head turning obnoxiously loud exhaust and they discover you removed the CATs completely. On a bad day, you could end up doing the weekend until the judge can deal with you on a Monday.
Anyhow ... listen Jr, you do what you gotta do, if it pleases you to dump the CATs and run around like that then by all means go for it. Whom am I to tell you different.
Also, I'm no engine expert so pardon me if I didn't get the above explained 100% correct but a little searching on the interwebs would suggest removal of CATs is an overall bad idea.
I'd be right there with ya if we were entering that LS into next weekends demolition derby ... but we are talking street legal and prolonged engine life here.
Overall it's a bad idea the way you are attempting to go about it!
Now I know you don't like when I tell you the truth much as we've discovered in the not so near past, so please spare me the backlash, I'm not in the mood nor do I give a ratzass.
Case in point: That tire that I told you wouldn't last when you put that plug in it, where clearly it was a tear near the edge as apposed to a puncture in the middle of the threads.
I recall someone loosing it ... yet here we are sitting on flats. 10-4?
You already know dumping the CATs is a bad idea, you don't need me to tell you this I'm sure.
It's not going to work and I'll give your engine 2 months max before I get to play yet again,
https://www.youtube.com/watch?v=rY0WxgSXdEE
You need new CAT's if they are clogged, dumping them and tucking the O[SUB]2[/SUB] sensors out of the way is NOT the solution .... Peace Jr !!!
