Kid_Lyrics
Notedbe careful, sitting on the hood or leaning on the fenders, those light weight aluminium panels can dent a lot easier that you would think.
Sent from my SM-G900P using Tapatalk
I been wastin away here...sick for past 9 days. Missed 5 days of work so far with this flu that attacks bronchial and lungs. Living on soup,antibiotics,Vitamins and supplements like CLEAR LUNG.
Have a bunch of maintenance and working on other peoples' cars I would have gotten done but for this.
Just watched Denzel Washington in that movie,UNSTOPPABLE.LOL! don-ohio^)
Probably from breathing antifreeze fumes caused by leaving the degas cap loose.
Then, how come I haven't been sick for the past 2 weeks?
I'm just saying.
If you're going to poke holes in his boat, make sure there aren't others in it with him.
Well that wad when the battery was brand new. .. I had it tested right after installOvercharged? Why? Should read about 14 to 15 volts when running. At rest, the battery ought to have at least 12.5 volts. don-ohio^)
and that right there is why I wont own a ford with out a key pad on the door!
then again, being able to unlock my car from my cell phone is also very helpful.
since it was as you were leaving for work, I take it you don't have a second key? I would make sure to get one as soon as possible, even if you don't program it to start the car (which is kinda silly not too) at least then it can be used to unlock the door/trunk in just such a case.
Funny enough, i had just put my key in my bag that I was moving to a location..and put that bag in the car last night....
Wow..... that's creative..that's last bit there..Take the expensive key and have a copy made,just a regular key. My wallet has a coin compartment,so I just stick it in there. IT will open the door and trunk.
If you don't have the money to get an extra fancy electronic GIZMO key right now,just do that.
If you don't have a coin storage in your wallet,do what my Dad(called the absent-minded professor by many) used to do and I do it too: Remove whichever screw on the license plate, put the key behind the plate and run the screw thru it to tighten the plate. The key is always there so you can get into the car. Sometimes you need to drill the key head a little larger for the screw to fit thru it. don-ohio^)
One kid told me he wouldn't even cut me a basic key because the wrong key could set off my alarm...
I've not locked a key inside a car since 1992. The reason is ever since that time, I've never locked a door without having the key to that door in my hand.
For that matter, I don't go through a locking door without having the key to that door in my hand. Keeps me from locking myself out of the house.
Something to think about getting in the habit of.
