Long_Island_LS
Recently had the car lowered on Eibach's pro kit. I read a lot about coilovers/springs & I basically went with springs because of the $$. I only have 42k miles on the car, so to swap out the struts before necessary is a waste IMO. The coilovers were gonna run me a lil over $1500 installed...and the springs were gonna cost $540 (alignment included) - so i decided to save the $900 for now.
I had the shop cut 1/2 a coil off the front springs - the rear of my car was already a 1/2" lower than the front because of the music and 2nd battery I have in the trunk. In the rear I used spring helpers in between the coil of the springs (the same ones that QuickLS used) to help prevent the car from rubbing over dips (hopefully anyway).
Based on what I read, I expected the drop to be about 1.25" in the rear and 1.5" in the front. The end result was about 1/2-3/4" lower than expected. I have about 1.5" in the rear and a 2" drop in the front. I still have to take final measurements.
Anyway Ill upload more pics when the 19's are on. Here are a few for now.
Before
After
Before
After
Before
After
Before
After
