dnsherrill
I appreciate you taking the stealer's side on this- good to be objective. I'm 100% certain they disconnected it and took the relay; I carry an xcal2 scanner/tuner all the time. If I ever get a CEL, I identify it right away. The smog pump diverter/flow direction valve has pulled a P0411 periodically in the past. That's mechanical (pressure related).
The P1414 and 1413 both pertain to voltage. They both came up for the 1st time after the stealer gave it back yesterday. Thanks to them I had no line voltage to the pump and no relay, hence the new and different codes. P0411 is mechanical, 11414 and 1413 are electrical. With the open ground it read excessive voltage. Now with no relay it reads low voltage.
But you're right, I have no proof. All I can do is ask them why they went in the drivers side and I have a new part on the pass side. At that point he'll prolly deny they ever said they went in on the drvr side
