thaywood
My sister called this morning. The water pump's gone on her '05 Exploder. Looks like I'm gonna be fixing yet another vehicle...I should start charging for this shyte...
When you get done you can swap the timing cover gasket on my 99
Just keep a mental note of it for when you need help with something.
Hey, you remember when I.....
...I need a garage, and a lift, and another Mark VIII and ...etc etc!
 Well, I'm going to drain out the "F" tomorrow and refill it with Mercon V and see what happens. If it quiets down, I'm good to go. If not, I'll be installing the new pump. Either way, I'm getting the Exploder roadworthy tomorrow so I can get my damn Lincoln back!!!
 Well, I'm going to drain out the "F" tomorrow and refill it with Mercon V and see what happens. If it quiets down, I'm good to go. If not, I'll be installing the new pump. Either way, I'm getting the Exploder roadworthy tomorrow so I can get my damn Lincoln back!!!Anyone have a link to a lower control arm replacement? Just so I do thing's in order!
also noticed that the driver's seat in The White One is missing the back rest controller; how do I fix it?
factory service manual, money well spent
http://www.ebay.com/itm/1994-LINCOL...ure&hash=item3366f679ac&vxp=mtr#ht_2329wt_932
93-98 the same?replace the switch
I'm sure someone can expand on it...I haven't done all that work (yet) so I can't advise; that flea bay seller is in Wisc, shipping should be quick...when I finally got around to buying a factory manual, about 95% of my questions were right there in the book...funny how that worksI plan on doing this next weekend (if it doesn't rain), can't come up with one by then, was hoping you guy's could enlighten me but....
I'm sure someone can expand on it...I haven't done all that work (yet) so I can't advise; that ebay seller is in Wisc, shipping should be quick...when I finally got around to buying a factory manual, about 95% of my questions were right there in the book...funny how that works
93-98 the same?
for all intensive purposes the seat (with the broken controller) is totaled, I can take a switch from another seat (like my extra one, but then it's defective...or find a trashed seat with a good sw.
dont think so.....
dealer says yea, 93-98 the samedont think so.....
i was having issues with my sunroof not closing all the way and closing it manually, so i took out the motor thinking it was cable driven, when it was gear driven.i cold not get the pieces back together so i left the gears out put the motor back and it works just fine.
re; seat sw., I wonder if I could use the one that's on the pass side?..or what other Ford/Linc cars use the same part...guess I'll call the dealer to get a part # and see if they'll cross reference it
