Hi All:
Replaced my degas (second time since Ive owned my 2002V8 lse..bought her new) bottle a couple months ago. All was well. The upper plastic connector (tube that connects to the thermostat tower) broke a couple weeks ago. Turns out the plastic began to crumble where it connects to the upper radatior hose. Couple pieces of the plastic fell out onto the ground (under hood) when I removed the hose...but I definitely didnt see ALL of the small pieces of plastic. May have fallen on ground..or may have gone into the cooling system.
Either way..replacement went fine..bled system per procedures. no over heat at all..but now I get no heat. Just barely room temp air from any/all vents. A/C still works fine and blows cold out of all vents. But no heat.
Doesnt sound like DCCV. Is it possible something is clogged? But if something was clogged...wouldnt I get overheat due to poor or lack of coolant circulation?
Also..after driving awhile both upper and lower radiator hoses (two fattest hoses on either side of engine) get warm/hot as they should. Ditto for the smaller diameter hoses going to/from the plastic part and the cooling tower.
Suggestions?
Still sounds like t-stat to me.
