420ss
out of the blue, no warning signs at all, i go to try and start my 97 LSC and all it does is keep on cranking the motor, but wont start, it was running perfectly the night before, so i check the schrader valve (the pressure release valve on the fuel rail) and nothing, now keep in mind that i just replaced the fuel pump and i haven't even put 800 miles on it yet. so i checked all the fuses and relays that have any thing to do with the fuel pump, hell i checked ones that didn't have any thing to do with it, and they were all good. Then i moved onto the fuel filter in the fender well, i removed it, it wasn't clogged, then i turned the key and no fuel at all came out of the now open fuel line. now is there something i'am missing here? did i just get a faulty fuel pump? is there some type of control module that my chilton manual does not know about (which wouldn't surprise me seeings that it doesn't even show the C.O.P set up for the ignition system, and the book says it covers my year) so any help and/or insight onto this issue would be greatly appreciated, and thank you in advance my fellow LVC'ers cause you guys have helped me through this whole saga that brought my mark back from the dead once, and i know you guys will help me through this one
