Ok, Did a search... (didn't quite yield what i am after)
Wiper Malfunction Symptoms
Wipers work fine in all settings, park fine too. However, after a few minutes they start going slower, then start jerking, then stop, then start again. They don't do this in highest speed setting.
I took the arms off so i could run the wipers without possible drag. Same thing, although more random. They start normal, then get slower and slower... Then fast again., then slow again etc.
I believe the MFS is ok, as the wipers change setting with each click. I believe the module is ok too, as it always clicks upon a wipe.
So, bad motor then?
Driver's Mirror Glass
Mirror got hit and it has gone too yellow to use.
I have removed the glass from the housing with the intention of removing the outer glass. However, the 2 pieces seem to be stuck together very well. (already cut my hand - Lol)
Any tips on separating the 2 pieces of glass? Don't care about auto dim anymore.
Thanks for any help!
Edit: Nevermind the glass, was able to separate the 2 pieces with a utility knife. Only thing is, mirror broke in one corner Heck, I'll get a new (DOT approved) conventional mirror and replace it. That dimming fluid burns the skin - my hand is bright red! Lol.
So, bad motor then?
