ILLS
Thats exactly what I was implying, modern piggy back systems and factory modified or emulated electronics lack the ability of monitoring and adjusting fuel pulse width by using wide band feedback while in boost.
Are you including modern vehicles using SEFI and full custom tuning with the stock ECM in that list? Based on the wording I would think you are. You are correct that those vehicles do not continuously monitor their WOT AFR's with an active wideband. However when you are tuning those vehicles you will command a given AFR in open loop and then while you do have a wideband attached you will calibrate the actual open loop AFR's to match commanded. Once this calibration has taken place then your AFR's are good to go even when the wideband comes off the vehicle. That process, though overly simplified by the explanation in my last sentence, also calibrates load correctly which is what other items such as spark advance use as a cross reference for what cell to pull their spark value from. I do recommend going with the bigger standalone systems when getting much more serious and running one heck of allot more power. They do have more adjustability catering towards a race vehicle than what a factory ECM can give. However in 99.9 % of cases the combination being used does not call for that extra equipment and the stock ECM with proper recalibration and supporting hardware will accomplish the task just fine.
Not a computer guy by any stretch but this 45yr old mechanic of nearly 30yrs LOVES modern electronics![]()
I agree that modern EFI tuning has come light years especially in the last 10 years.
