This Would Be A Nice Project For $7500
I'll wait till they're a few grand cheaper.... it'll happen
Yep, all the rich kids around here are getting them and they'll act stupid and wreck them and then those engines will be everywhere and not so expensive. Just give it a couple of years.
Don't forget a few trucks are getting that engine as well
Comparing the curb weight to that of a Mark8, if someone could do the swap I bet that would net low 13s right away in a Mark 8. 11s would be much more easily attainable probably with just bolt-ons. (Gears, exhaust, tune, etc)
can you put a crank in that thing and push it to 5.3 like in Driller's mark?
he has a boss 5.0 block with a stroker kit i believe. but i wonder if the same idea could apply here.
The BOSS 5.0 is the same block AFAIK, simply a different intake manifold on top.
Even stock a coyote motor will scream mounted in a mark/LS. Problem is you may not be able to keep the factory gauge cluster. It was done on the LS side with the old 302 but much different engine.
There is a kit to take it out to 351 cubes
