gnarls
It is a 1996 mark viii i have had the transimission replaced, rear end worked on and radiator replace thermostat and hoses replaced and it still runs hot.
No water in the oil at all no leaks from the motor. On the gauge at 80 miles per hour it runs at the bottom of the n in normal and in town it runs on the o in normal to the r. The old radiator was full of mud and gunk.It has been about 110 to 116 here lately but with the 3600 i put into the car i would have hoped for no more problems.
Is this normal ? Or is the next step replacing the water pump and then adding oil cooler with a fan and a extra fan on the radiator? Or finding a bigger radiator maybe 4 core with bigger fans?
I am getting to the point now to see what i can get for the car
It has 68k miles on it and it is or has only a couple dings and no leaks.If i could get 5k to 5500 i could break even.
Thanks again
Thanks again
