BradGroves
I posted about my brake light/fuse problem about a week ago. How the car would not recognize that the brake was applied and would not shift out of park. If you did not see that, the neon seemed to cause a short that blew fuse 32. I disconnected the neon under the trunklid itself, now it has come to my attention that although the brakelights work when applied the rear running lights (when headlights are on) are not lit. what could be the problem here, I assume it is because I'm leaving that neon disconnected, It would keep blowing the fuse otherwise. Do I need a new inverter and if I fix the neon, will that amend this or are the two unrelated? Thanks
