UltimateSVT
- Joined
- Jun 21, 2009
- Messages
- 4,602
- Reaction score
- 166
I've had no good luck w/ ebay HID's
How bad are they? What experiences have you had?
DDM sells an error code eliminator
but I don't know if anyone has tried it in there mark.
Also some marks need the extra wiring harness.
I never got a message in any of the 3 gen 2 that I converted to aftermarket hids. Gen 1 seem to do it no matter what but gen 2
I never use auto on anway, even with the stock HID's.
I feel like it takes unnecessary life out of the bulbs. When its getting dark I turn the lights on. I don't need the car to do it for me.![]()
Nice to see more people ditching the stock setup.
Of the couple gen 2's i've swapped to aftermarket hid's ive never gotten the error code either unless accidentally bumping the headlight switch to auto on.
I wouldnt disconnect the system completely, its good to know when a bulb or ballast is acting up or burnt out and the message center still works like factory with aftermarket HID's.
I feel like it takes unnecessary life out of the bulbs. When its getting dark I turn the lights on. I dont need the car to do it for me.![]()
I'm glad to see someone else saying this. I could see maybe turning it on if you park outside and you need that extra light to make it to your door and trying to find the key to get in but running around in the daylight with no rain and the headlights burning for no reason just seems retarded to me.
I agree with both of you but I'm lazy I guess... I have autolamp on all 3 of my cars & all 3 of them are set at :30 sec autolamp mode. It's cool not to worry about forgetting to turn on your lights.
What cable do I need to snip on my 93?
Brown wire with light blue stripe. On the harness (once you have it out) the wire is on the corner of that harness that's connected to the lamp out module. Just cut it and stick the module back in and put the little bolt back in place and you're done. 1/4 inch ratchet with a 5/32's socket or 5/32's nut driver and some wire cutters are all you need.
Since my SCIL is probably damaged. I need to disable the "Check Head Lamp" message. I've got to disable it. I'm using a relay to light them up. They come on normally. I'm using resistors, but they aren't eliminating the message. Does anyone know if the wire to cut is the same as the Gen 1's?
