Short and simple. I replaced the Upper/Lower Radiator hoses as well as the Degas cap and Engine fill cap last weekend. Bought new coolant even though the old stuff was from last August when I replaced all of the other cooling plastic components. I did the bleed out procedure according to this just like I have the previous time.
http://deneau.info/ls/s6x~us~en~file=s6x33004.htm~gen~ref.htm#extract_142
But my car decided to overheat YET AGAIN. I will admit that I was getting on it a little bit, did a couple third gear pulls up to 5500rpm. But was just cruising around town with a buddy yesterday and the temp decided to creep up to 3/4sh, floating up and down between 3/4 and half way. This immediately put a knot in my stomach because I've literally replaced everything. Just because I want to rule everything out, I'm going to post how I bled my car after the hose installation.
1. Removed Engine fill and Degas caps.
2. Opened heater air bleed.
3. Filled the Degas bottle and let it slowly equalize throughout the system. Did this until the coolant started to come up at the engine fill neck.
4. Installed Degas cap.
5. Slowly added coolant to the Engine fill neck until the coolant would completely fill the neck, and then slowly travel back down through the system. This process took several minutes until the coolant level remained at the top of the neck without lowering (filling system).
6. Installed Engine fill cap.
7. Started engine and turned the heater speed to full blast and temp to 90degrees. Air was set to the defrost (Windshield position).
8. Waited for coolant to exit the heater hose. It would exit in periods of 5 to 10 seconds at a time until it eventually came out "Steady" with no breaks. This process was maybe a minute or two tops. Closed the heater bleed valve.
9. Allowed the engine to idle for 5 minutes. I did not have to add coolant to the Degas tank.
10. I opened the heater air bleed and had a small amount of air purge out. Closed the heater air bleed.
11. Held the throttle at 2000-2100rpms for 5 minutes. Hot air was coming from the windshield vents great, and everything was sound. No coolant leaking or anything out of the ordinary.
12. Changed the climate control unit to 75degrees and allowed the car to idle a couple more minutes.
13. Shut the car off and allowed to cool.
Did I do something wrong here? I don't believe so but God only knows. I want to be 100% certain because I have no idea what the hell to do anymore. I've dumped $750 in cooling plastics and have completely overhauled the system with the exception of the radiator itself.
If the bleedout procedure I've posted was correct, then I really am at a complete loss as to what to do now. Any logical advice would be greatly appreciated.
I mean it's just so weird because the car will say it's overheating via the temp gauge but I hear no coolant boiling or anything from the engine. I just don't know what to do anymore. And this doesn't happen all the time. I've went for a couple 35-45minute drives since last weekend (The install), and have had no abnormal temperature gauge readings or anything. Then all of a sudden it ****s on me again.
I did talk with my wife and have decided that if anyone in the West Michigan area would like to make some money, I'm offering $500 for your time if you can fix it. I'll pay for whatever parts nessecary, but I have replaced everything so I have no idea what to do. But like I said, $500. Already talked it over with my wife and she said and I quote "Just get the ****ing thing fixed". So that being said, if anyone would like to fix it my offer stands. Contact me via private message and I'll give you my phone number.
Any DIY advice is appreciated, but I just feel so defeated by this fkn thing now I can hardly look at it. As fine and sexy as it is lol. Anyhow God bless guys, let me know what's up.
