FreeFaller
USAF LS8
Just wondering what the best tire out there is for the LS.  It seems that on the web alot of people don't like the Michelin Pilot MXM4.  What are you guys using? :feedback
			GoldCoastLs said:im using the toyo proxies 4, 245/45/R17....they are pretty sticky, and have a very good treadwear rating, the also have a AA traction rating, good bang for the buck.
FreeFaller said:Thanks for the input guys. Now I can get to researching your suggestions. :V :yourock:
LBK_LS said:what does the LS'ers think of going from the 245/45/17 to the 245/50/17??? I know it's only a .5" on each side.. BUT...... I want something with a bigger sidewall.
I like the bigger sidewall, kinda fills in the wheel well alittle bit more, and probably smooths out the ride a little bit
luckieleo said:mine are 235 50R 17...
The first number doesn't just have a lot to do with the width--it is the width of the tire in mm. The second number is the aspect ratio, the height of the sidewall as a percentage of the tire width (the first number), so if the first number goes up and the second number goes down, you'll have a wider tire (and thus a larger contact patch), but not necessarily a taller tire (which could be good, since you may not need to recalibrate the speedo).dropped74 said:Doesn't the smaller first number somewhat cancel out the second number, so the 245/45/17 is pretty close in side wall as the 235/50/17. The 235 has alot to do with the width of the tire so it would make the tire somewhat smaller I doubt enough to make a difference but I don't think that the 235/50/17 would give you a larger sidewall.... Any input here would be good because I would also like to know and if this does have a larger sidewall do you have any close up pics. I would like to see how it looks!!!
These are phenomenal tires. I just replaced a set, but with Goodyear Eagle GT HRs. They're 90% as good as the Michelins.LS4me said:Michelin Pilot Sport A/S.
