Let's play "Guess my 1/4 mile time"
Message center will inform him of problem, and he'll turn around and go home, no one gets a cookie!
Dr. SVO phd
*right click, save*
I'll make some updates on my Droid from the track. Hopefully I get in some decent runs, it should be really busy tonight.
Change of plans. Temp is about 10 degrees above forecast and my 20 foot above sea is correcting to about 1800 feet. Next Friday wil be a out 15+ degrees cooler so I will try then. I will get a decent baseline one way or the other.
I Win A Cookie!!!
Dr. SVO phd
Wus! :p
See what number chasing gets ya... a boring night at home when you could be having fun at the track!
that aint no shiitt...
hell he inst even chasin ET, hes chasing the weather...craaaap.
put 'er in the beams, you can concern your self with "numbers chasin" after you get some runs..
since you understand DA, then the DA shouldnt keep you from going to the track
Dr. SVO phd
fuggen jeff...damn gnomes and their crystal balls.
thats cheatin..
call me later with my lotto numbers, m'kay?\
B.S... the Sniper is capable of changing any of the parameters in the PCM that SCT can...
can you tell me at what rpm fail safe cooling is enabled and how many cylinders are shut off?
or something first grade level..
at what background loop time does it disable the missfire monitor?
Eh, I got dinner at Famous Dave's with the wife, a new weed wacker at Sears and some beer and an Italian sub for me now. Turned into a decent night. I don't exactly want mineshaft air, but I don't want High Sierra elevations either.
