twinbopilot
I bought some amber dual-stage 3157 48 bulb LEDs off Feebay and installed in clear corner headlights. Looks killer but stays on "Bright" all the time, even though its a two-stage 3157 bulb. I wired in resistors, spliced between the ground and the "major" wire (turn signal), but still throws a bulb out message when you have the running lights on AND the turn signal. LED turn signal works fine when running lights are off.
Anybody successfully get their LED front signals working right?
I may be able to eliminate the need for resistors by installing an LED electronic flasher unit, but I'm not sure where its located on the car or what the part # is on it. I found a site that said it was a Tridon BSM flasher, but it had no photo and I can't find any further reference to it.
Any and all ideas are welcomed.
