Problems solved.
themis69. I tried putting in the amber bulbs as brake light, which are the brake bulbs you got but in amber, and the bulb out message did not appear. Just putting the resistor in parralel on the running lights wire and power wire will take away the bulb out message with or without an LED bulb since the resistor's load will be there. You must have wired something wrong for it not work for you. By the way, not sure if you have gen1 or gen2, but if you have a gen1, you colors might be different.
Like I said before for the brake bulb LED's, the parallel resistor is to get rid of the bulb out message and the resistor in series is so the brake lights flash brighter when you press the brake with the running lights on, instead of them being bright all the time with the running lights and not lighting brighter when the brake is pressed. The resistor in series goes on the runninglights wire (gen2 black/blue) , in between the bulb and the resistor in parallel.
twinpilot and everyone else.
For the front turn bulbs, to make them work with the running lights, you need to add a resistor in parralel. Not sure where the cut off is but a 47 ohm resistor made it work but made them stay dim. A 10 and lower resistor made them work like a normal filament bulb would work. I soldered in a 6ohm 50w resistor from v-leds because it's what I had around.
This will also allow your angel eye rings to flash when you lock the car when you install the LED bulbs as well. Andrizzle, since you like it without the amber bulbs lighting up with the running lights so you can see the angel eyes better, you dont need a resistor, but for those who want the rings to flash and the ambers to be on with the rings, just add the a 10 or lower ohm resistor in parallel with the running lights wires. Gen2 running lights wires on the headlight turn bulb harness are black/blue and black/white. Gen2 running lights wires on the car's harness are black/white and grey/red.
Adding a 10ohm or lower resistor in parallel with the running lights should also fix the problem with the dual turn signals that light up white then amber when you use the turn signal.
By the way, I noticed that my rear turn signal stayed on very dim like the interior LED lights use to. I added a 100 ohm 1w resistor in parallel to the 2 rear turn bulb wires to shut them off completely
Done, going to sleep.
