DaleGrib
I have a 2006 Lincoln LS and the parking brake is not working at all I have tried the reset procedure with no luck.
Also the traction control light warning is lit up on the dash and I also get the Check Advanced Trac, Service Park Brake
The ABS light is not on at all it does work though as I can see when the car starts up.
I ran a code reader on the car and I get the following errors.
C1785 EBP Motor Output Open Circuit Electronic Parking Brake Module REFER to Section 206-05 .
and
U1262 SCP (J1850) Communication Bus Fault Electronic Parking Brake Module REFER to Section 418-00 .
I am assuming I will need to replace one of the two parts that typically mess up on these. But was hoping maybe I could get an idea of which one I need to replace.
Many Thanks in advance
I will also add my other codes as well that scanned
I know what most of them are (pretty sure anyway)
(WARN) [20:49:21.135] DTCs in PCM: P0430-FF, P1000-FF
(WARN) [20:49:21.581] DTCs in OBDII: P0430-P
(WARN) [20:49:25.854] DTCs in ACM: U2025, U2005, U2008
(WARN) [20:49:27.622] DTCs in IC: B2879, B1875, B1352, U1262
(WARN) [20:49:29.101] DTCs in GEM: B2316
(WARN) [20:49:30.515] DTCs in EPB: C1785
B2879 Fuel Tank Jet Pump Fault Instrument Cluster REFER to Section 413-01 .
B1875 Turn Signal/Hazard Switch Signal Circuit Failure Instrument Cluster REFER to Section 417-01 .
B1352 Ignition Key-in Circuit Failure Instrument Cluster REFER to Section 413-09 .
B2316 Mirror Passenger Vertical Feedback Potentiometer Circuit Failure
I know I have to replace the turn signal switch and the jet fuel jump as well as the cats most likely but the others I am stumped on.
Might I also add I bought the car with these problems! Trying to get it legal so it can pass a inspection
and
