jtmforever
I am going to install a 2.5 pipe true dual exhaust system from the manifolds with two magnaflows. Do i have to install an x-pipe or can I just run two pipes back? What are the pros?
			While we're on the subject, I have a quick question: the LSC's came stock with true duals, correct? Do they have any sort of crossover(s) built into the system? Just curious.
	Code:LINCOLN MARK VIII EXHAUST LAYOUT (BASE MODEL) x = cat, R = resinator, O = mufflers | | x x \ / x \ R | | / | / | | | O OCode:LINCOLN MARK VIII EXHAUST LAYOUT (LSC MODEL) x = cat, O = mufflers | | x x \ / x \\ || || / | / | | | O O
Yes.Will an x-pipe or h-pipe increase hp compared to two straight pipe?
You got that backwards Sapper. H is deeper, X is raspier.I recommend an X over an H, for tone purposes, an X gives a more deep sound while the H sounds kinda raspy. Double X is a bit much IMO, but it'll make it a tad quieter
I need to cut the X off my scrap heap 93 and use it on the 98I bet it's gonna sound killer with the MagnaFlow Bullets I'm using
H
or
X
pretty simple.
