the1andonlyGR81
recently came across 98 cobra intake. for those who dont know ive got comp cams, 80mm mass air / cold air k/n, kooks headers. ive heard itsloss down low is minimal 3-5 hp while up top 25hp., mr stromberg, dlf great article on lod,let me get my checklist ready
1. drill/tap vaccuum line in lower manifold for booster
2. will the stock throttle cable work
3. do i need to flip over throttle body if throttle cable works, if i need new one do i still need to flip it?
4.egr, i plan on deleting all of it, otherwise i need to fab special line where can i get delete items including ones on headers, and when i remove smog pump what size belt do i need.
5. (DLF)on the rear of the cobra manifold is a vacuum fitting on your lod thread on page 1 but it appears to face away from brake booster, there is another on the side facing at 45 deg angle can i use that?
6. the iac valve on the front will i need to get for the 98 cobra or will the one from the mark fit?
7. the plastic air tube looks like you used the mark tube, yes? i know its in a different spot and angle i can modifrt that, but if im reusing stock throttlebody it should work.
and anything else i may need. trying to keep cost down, what gasket set will i need?thanks,THEGR81
