sprocket
Today I changed the injectors. It started really hard and had a misfire for a little while. It basically started hard like it always does after sitting for any length of time.
I drove it around. The tick that sounds like a lifter is worse. I can hear it in the car. It might be ticking from more than one place. It runs OK when up to speed but the idle is still a little off, and it isn't quite smooth below 40mph.
Here's the killer: The low coolant warning came on and stayed on. It comes on sometimes, especially when first started, but it always clears. My other '96 does the same thing. This time it stayed on, so I checked the reservoir when I got home. There is plenty of pressure there when I loosen the cap. And yes there was something in the reservoir but it didn't resemble coolant. That's right, oil in the coolant and I think it might be a fair amount.
Oil filter adapter gasket is a possibility as I did see some oil spots on the ground lately and I can't figure out where the leak is, but I think it's in about the right area. It's just that it seemed like a lot of oil in the reservoir. The oil level isn't low though and I don't see coolant in the oil. But then there's that tick that's getting worse which suggests possibly an oil problem. I think I had better change the oil so I can get a good look at it.
