joegr
would you recommend taking it to pepboys?
No, for the love of God, NO!
[/QUOTE]lets say you take it to a cheaper place that only charges $55 an hour, then they fukc around with it for three or four hours ($165-$220) and then it turns out that they cant even fix the problem because they dont have access to all of the important tools like a dealer does.
I wouldn't ever take my car to a non-dealer mechanic unless i personally knew somebody there that i had confidence in being able to work on a car like this.
didn't you already say that you had mechanic'ish friends look at it, and that may have already made problems worse.
the best technicians usually get paid the most, places cant charge the least amount in town for work, and pay their techs the most at the same time.
yes I will listen this time but one more thing I was reading thru some threads and I see that some ppl jump something in the fuse box to test the starter to see if the starter attempt to turn if anyone knows what i'm talking about can they please give me details on how to do this before I tow it to the dealer and find out the starter was shorten or bad wire? and get charged like a million dollars
for the record, i would have a hard time taking an 86 civic to have work done at Pep Boys.
this is true is these the places that diagnose for free or strictly take it to a ford dealership?I think your right thou...damn smh
can your hear the fuel pump when you turn the ignition on?
No I cant here the fuel pump at all. Also is safe to test it with a digital multimeter if so How do i test it.
which connections? which one is the fuel pump fuse and relay? thanks to you guys so far i'm almost there
At the replaced fuel pumps.
Anything I can clean the connections with
Electrical contact cleaner. The first thing I would check are the connections.
I'm getting good power to the fuel pump but still no start I dont hear the fuel pump at all?
this is true LOL. i think you and the other people have me on the right track cthu after dealing with this lincoln I will be a expert. Honestly could this have something to do with the ssp4 Rem relay?
This is the problem here. Connecting the pump straight to 12V was a bad idea and may have (probably didn't) damaged it.
You thought you had power to the pump, but apparently you don't.
I'm sorry, but you are in over your head. You really should get it diagnosed/repaired and be done with it.
but i think im just going to make a switch and call it a day
