im sorry i know this has probably been discussed a hundred times but i did search and did not find the answers im looking for .
1. im getting 4.10 gears and trac lok , is there any reason why i cant take the drive shaft i have and get it professionally balanced? 500 plus gears is not do able at this time.
2. there are many discussions on here about pullies and what should and should not be used, what pulleys should be used and what size are they? what is the real benefit of these pulleys?
3.i have also seen on here that getting an electric waterpump would help too , what do i need to do if i do change it to electric? do i have to wire it in to exsisting wiring or run my own to toggle or ignition and what about fan override? what do i need to order for that, and where do i order this stuff from?
4. i read geno said they do the gears with a one wheel one axle method , is there an instruction thread on this in here somewhere?
sorry for all the repeat questions but i love my 97 mark 8 lsc and am on a budget so i waant to do this right the first time instead of my usual tear into it and do it 10 times till i get it right method.
thanks in advance for any help you can give me.
jt
jt
