26) Connecting the factory front tweeters to the aftermarket double DIN system will require finding the Right and Left input wiring to the factory front amplifier mounted under the steering wheel/dash area (has off white plastic with aluminum heat sink 4” X 2.25” in size). Connect two RCA cables R & L from the aftermarket radio Front RCA output terminals. Disconnect green connector from the front amplifier and access the wires that go into pin 1 (Left channel + ) and pin 2 (Right channel +) and pin 3 ground for both channels. Cut all three wires two inches away from green connector and connect the RCA Right (red) wire to connector side grey wire, connect RCA cable Left (+) white wire to connector side white wire. Connect both RCA cable shield grounds to the bare wire from pin 3 of green connector. Insulate all 3 wires then reconnect to amplifier. After connecting turn on radio and make sure that the speaker in the left side of the console is Right channel and the speaker in the right side of the console is Left channel.
Where did you find the Front Amplifier???
I hooked up a After Market Deck a couple years ago.... and the tweeters never worked after that. I assume that I simply never hooked it up. But never came across a good explanation as to why... until now!!!
But from this write up... and pics... I still am not sure where its located.
Info Pls?
