G-RELL
FULLY DIPPED LS
you know what else would help... no plastic
man I am catching HELL trying to get the lower hose off lol...I got the clamp pulled back (going off of the picture shown in the thread) and it's like that hose is baked on. As we know, there's no room to work next to the firewall, so I was wondering if anybody had any tips on how to get it outta there. Thanks in advance.
and yes....unfortunately I have the dorman bottle....can you please give some insight as to what issues I will be facing?
You'll be doing this again next year since the Dorman has quality issues.
Your cap may not fit well enough to hold pressure.
You get what you pay for.
I have never heard of that one. Motorcraft OEM is what you need and the cheapest I have ever seen them is $140ish
I got mine from Tasca Parts. I purchased mine from their direct website but here is their ebay listing.
http://www.ebay.com/itm/FORD-THUNDE...A-/230709297411?forcev4exp=true&forceRpt=true
The upper hose with an end cap - is that the bleeder valve?
I don't know if I'm not doing the bleed process correctly. When it comes to the stream coming out, is it supposed to be a slow trickle or should I be looking for a stream something like what comes out of a water fountain? After I do everything and I take my car for a drive, the fan kicks on again and the car starts to overheat, but nothing is leaking a all. Then when I turn the car off I can hear a bubbling as if air is in the system again. But when I do the bleed process again, there's an immediate stream of coolant...what am I doing wrong?
http://www.lincolnvscadillac.com/showthread.php?t=78739
