Another Barnyard Find
GMAN
Spring, Texas, United States
Today, I went out, and found this 95 out in the country. I find a lot of em out here in the small towns. This one, the owner says the air ride quit and they parked it. It's been sitting since 2003. I may pull the trigger on this one.
yeah saddle makes me want to gouge out my eyes with a rusty screwdriver! sitting for 7 years damn!!!! i bet mice are all over that car man.
i'm not a fan of saddle but the car appears to look good int/ext minus a dent i saw on the drivers door..if you can get it to run(prob needs a jump) and shift gears and can get it cheap go for it. Def lowball them as they obviously have no use for it and will prob take anything you throw at them.
before you buy it i would be searching the underside of it and the engine bay for chewed up wire harness's if mice ate at it you could be in for a world of hurt. check the air box for mice, the frame, trunk, around the wiper cowl, and make sure the harness in the engine bay isnt chewed up. alot of people overlook the damage that mice can do to a car, its never visible!!
The chewed up wires part is true, but if that checks out I would snatch it up!!! I can find them like that for 500 all day long around here!!! How much do they want for it?
Mice isn't a big worry in this neck of the woods where this car is in Texas. It would be snakes. Mice don't survive out there. I'm going to find out more about it later today. I am expecting around $500 or less would be my offer. Hell, I got my 93 for $300, and it was running. I am going to shoot low. Like lower than the car is now low. :p
I like it! I would be all over that for $300! I need a secondary ride and that would be a great little project as I like the green/tan combo, always did.
Gonna have some gremlins from sitting so long. Change all fluids in it and I bet the brake lines are no good plus the cooling and vac lines are prolley rotten. Its still a nice clean canvas to start from.
Actually Sapperfire needs a new car really bad and all that stuff I mentioned is new on his so it could be swapped over. :D
