the a/c will blow out of the floor and defrost when i press the buttons on the eatc to change them. But it will not blow out of the vents. I pulled vacuum and it says i got plenty of vacumm(20 lbs+-). When i disconnect the plug(plug with yellow,red,black,blue lines coming out and into it) behind the glove box it changes to defrost only, when i connect the plugs together it goes floor and defrost. Bought an EATC off of jamie and that did not help.
The only conclusion i can come up with is the yellow vacuum line that comes out of the back of the eatc and runs up into the dash has come loose on whatever it is attached too. What does that yellow connect to if anyone knows. Any other suggestions would be nice also. help me
this is on a 98 lsc if that matters. The black lsc i bought from jamie.
