98 Only J-Mod Instructions - Sticky Please!
Lincoln Mark VIII
  1. NoLimit95
    NoLimit95 Dedicated LVC Member
    8,438
    394
    Mar 14, 2008
    Madison, Alabama, United States
  2. 94m5
    94m5 Dmaup's Daddy
    5,455
    227
    Oct 22, 2004
    Colorado Springs, CO
    Stickied.
  3. Sapperfire
    Sapperfire Dedicated LVC Member
    6,641
    499
    Dec 4, 2009
    Waco
  4. Warden
    Warden Dedicated LVC Member
    655
    14
    Jul 21, 2005
    Bellingham
    ^ I see.
  5. NetKeym
    NetKeym Dedicated LVC Member
    1,006
    61
    Feb 28, 2011
    Gulf Coast
    Nice video! However, if he wants to make it so simple and use only 2 drill bits, he very well could have used the same bit he used on all the other holes on the #10 hole, also. It would not have hurt anything and he could have just used 1 drill bit for the entire plate.
    To each there own and this is a great video for anyone wanting to do this themselves!
  6. PenGun
    PenGun Dedicated LVC Member
    580
    63
    May 2, 2012
    BC
  7. fastmark1993
    fastmark1993 Dedicated LVC Member
    2,151
    19
    Aug 30, 2009
    Edmonton, Alberta
    Is it safe to just drop the 1-2 spring and not mod the valve body?
  8. chris2523
    chris2523 93 Mark VIII
    7,862
    740
    Nov 8, 2007
    Central MO
    i would rather mod the valve body and not drop the spring...
    in fact, i did just that.
    the bigger holes do more than just shift the trans quicker.
    the faster movement of fluid also helps cool and lubricate the trans more efficiently.
  9. 1sik32valve
    1sik32valve Active LVC Member
    162
    16
    Feb 14, 2013
    San Bernardino
    I have always wondered this I've been seeing that mid or late 97 models have the updated trans, does this apply to them too? And does anyone know an around about build date of the update 97 trans?
  10. chris2523
    7,862
    740
    Nov 8, 2007
    Central MO
    yes. the 98 trans got better hard parts. but they didn't really change the valve body. friction material, mechanical diode, better case design, bigger OD accumulator. and so on. i've seen it reccomded all the way up to 04 transmissions. when they basically dropped the 4r70w.
    in the end, even DLF jmod'd his trans. he had held off on it for a while.
  11. KStromberg
    KStromberg Dedicated LVC Member
    2,428
    315
    Jan 11, 2011
    New Brighton, MN
  12. dnehthend
    dnehthend Dedicated LVC Member
    697
    14
    Feb 6, 2005
    Phoenix, Az
    I drilled out the holes according to the specs in the PDF but left all of the springs alone. To me it's perfect. It shifts quick and smooth, you can't even tell that it's happening unless you are really getting on it.
Share This Page
