Outlaw94
In overdrive it will jerk when going up hill.The trans fluid level is good it has newer plugs,wires,clean air filter and the fuel filter is about 2 1/2 years old.The rpm's don't change when it does it.Any ideas whats causing it? hope it's not the torque converter or OD slipping.Last night when backing up after leaving a store I had to stop because a car was coming and it felt like it was starting to stall a little.Then on the road going about 50 it was jerking quite a bit so I turned off OD and it was fine.Does sound like a trans,misfire or fuel problem?. I checked the fluid today and it was a little high so I removed about half a quart but it still did it going up a steep hill in OD but it was better then last night.
