Hi!
When I was parking at home I felt the steering wheel heavy and the steering noise came louder,I took a sneak peek for flat tire or obstacle, i saw oil dripping then the belt drive started to squealing, I turn the car off and open the engine bay,all was covered by oil.
After cleaning and refilling the oil reservoir I can't find the leak source.
Turn on the car again,If no steering movement no oil leak,if steering movement leak.
The oil it's dripping on the pulley so it starts to squeal and blows oil everywehere.
The power steering rack is dry,no oil marks.
The pressure switch on the hose near the steering rack was ok.
Power steering pump fittings looks ok.
PS fluid reservoid hoses looks good, no oil marks.
NO PS or electrical connector on back pump(is there 2 pump models?
What could it be ?
The oil pump itself ?
Tomorrow I'll inspect again the hoses and fittings.
oil level
Under ps pump (ps pump above ac port)
pulley covered by oil(yellow mark,i took the pic after cleaning.)
What could it be ?
oil level
