Fordman
So basically your saying ignore the beep, and just drive it!!! What your saying is this is a common problem, but not to woory.... Sounds good
Lucas05 3 said:Alright, I own a 2000 Lincoln LS with a V8 and it has been giving me problems ever since I purchases it. The problem as of now is the transmission I believe. When I put it into Reverse, it has a long delay before jumping back, and I mean jumping. Then when coming up a hill it switched to a lower gear to get more punch and when it punched, it stalled. The engine basically shut off for a couple seconds. It is also leaking a red fluid under the left portion of the front. I believe it is either transmission fluid or power steering. It is going into the shop for it's 100th time and will probably be there for another week. I would love to hear from you guys on your opinions.
eL eS said:I let my car idle down before I depart i any gear.
What happened to the A/C. Mine started blowing fuses like crazy a few months ago; I wound up replacing the compressor and clutch coil all in one shot. I dont remember if you said you car is under warranty but if it isn't you owe to yourself to buy the parts from 5 star ford.
What exactly does it do??Lucas05 3 said:Well, my car still stalls. I can't put the pedal halfway down anymore. Will someone please help me?
Lucas05 3 said:I recently have encountered the phantom beep. This is frustrating me so much.
limcolnlspimp said:i know it has mine. i paid 14,000 for mine almost a year ago and i have since sunk nearly 2000 into it for repairs. that does not count mandatory fluid changes.
Guys, Guys! Take your LS to Neill-Sandler FLM and see Jimmy Cox. He is the service manager there and is fantastic to work with. Just tell him I sent ya! :Beerlsbit said:Off topic, but did you get your work done at Ted Russel on KP? I think I met you there when you just received the quote. ??? I was picking up valve cover gaskets at the time.
ls2000j said:Ok, my lincoln ls 2000 is having some of these same problems you guys have listed. I replaced the transmission a year ago and it ran fine for about 4 months, then started to have problems, I thought it was the transmission again but when I took it in there they sad that is was the engine misfiring. I had all the spark plugs replaced which didn't solve the problem; the trouble code keeps pulling up bad coil packs, I change them and have problems the day I get the car back. My check engine light will come on for a day or so and then turn off for a while and come back on. Meanwhile my car still hesitates all the while. I am getting fed up with taking it in, getting it back to have the same problems over and over again. It also has the hesitation when I put it in to gear. How many lincoln ls 2000's are having this problem, and if so many can someone tell me if there is a recall for something on the car? Any advice or suggestions would help. Thanks
