Someone better jump on this fast for parts, the headlights look good and the grill is intact:
http://washingtondc.craigslist.org/nva/cto/3615478411.html
Oh cmon you guys have no faith, throw in a used engine,
coil conversion,
clean it up and keep it going!
I'd just fix the head gasket, if that's what it was and fix the cancer it has and keep it on the road. If the interior is trashed, then possibly part it but the only real money setting there is headlight housings, grille, corner lenses and maybe a couple of other things like the ECU, VLCM/VRCM, w/e people wanna call it. Other than that, everything else is cheap on eBay and coming from Washington DC, it might be a lil rusty. All depends on how it has been taken care of over the years. By the looks of the housings and grille, it appears it may have been garage kept but then the clear coat flaking changes my mind on that theory.
Shave the heads. Get new head gaskets. Done and done. Used to do it all the time back in the good ol' days Still easier to just replace the whole engine as a unit than to fix the heads though.
You can't just fix the headgasket if the heads themselves are warped.
Rust in DC? Do they really have much for winters there? I've been there in late winter or early spring and it was in the 80s
Who says it has a blown head gasket? The owner? Why assume he knows what he is talking about? I would go look at the car and start it. I would check the exhaust for odor. I would check the coolant. I would check the oil and the oil cap for film.
I would NEVER assume it has a blown head gasket just because the owner say it overheats. These engines aren't known for blown head gaskets. It might just need the cooling system bled.
It probably just needs a motorcraft thermostat put in it.
I'd fix & save. It's a BoB 1st Gen LSC.
My '96 used to overheat a lot. Until I learned how to properly burp it and got a 160 degree Mustang Cobra thermostat. After that, she ran perfectly normal all the time. Even a little on the cool side
BoB stands for black on black? From what I can tell the inside is cream, tan or grey. Not black. If you look through the rear windshield it's defiantly not black from the inside.
