1995 Indigo Lights/Black LSC Progress
New Year update: paint.
Finally all the same color.
Car was at the body shop for several weeks so not much progress since the last post.
still to do:
some kind of ebrake
trim pieces
grill
probably more
Hey did you use the stock fuel lines for the 5.0? If yes what did you use to connect the stock lines to the 5.0? Going to do a 5.0 with the 10r80 in the near future on my 93 and trying to figure out all the small ancillary stuff. Thanks!
It's the stock mark viii fuel line until the filter.
Then it switches to an fittings, braided line, and an aftermarket fuel pressure regulator.
It's a very straightforward setup.
Had to do a FPR because the Ford control pack doesn't support a fpdm.
Depending on what pcm or controller you use, you might be able to retain the fpdm.
If you have more questions, feel free to ask.
