custom97'Mark
1999 Cobra Heads anyone know if these will bolt rite on, and if it makes that big of difference for my 1997 Mark?
99 and 01 Cobra heads use a different intake manifold and therefore "will NOT fit w/o modification". Meaning you would also need the intake and a whole bunch of other crap just to put those heads on. The $$ will add up very quickly.
are their any heads off the cobras that match rite up? Whats some suggestions on heads for higher torque and speed?
Some that arn't a million dollars. I'm getting the 4.10 posi installed, and only realy care about speed in the quarter mile, but also a cruiser and highway driver.
could you use the continental adapters for c heads with b intakes?
96-98 mustang cobra heads will fit. and are the exact same head.
The Cobra heads from 96 - 98 are exactly the same as the 93 - 98 Mark heads with exception of the cams. The timing is different for more torque in the Mark and the Mark has a tad higher lift.
Wow. Glad you're alright.
I feel your pain......Got lucky and not the first burn on me at all. Just one cut on the right leg and that's it. I keep a fire extinguisher inside the car with me now, just in case but not even that would have helped that night. It over powered me and the heat was just too much inside. I went back in with one but it didn't phase that fire. The fire dept. was called by the lady across the street and they were here within 3 min and soaking the whole car down and everything in the garage. If the fire didn't ruin everything, they did with all that water. They then pushed it out in the driveway just in case it decided to ignite again. It snowed that night for the first time in years. People from 10 houses away heard the explosion and came walking down the road to see if everything was ok. After you have been inside a car that has done this, you would never have a full understanding of what it feels like. Me and injectors just don't speak anymore lol.
Who you tellin'. I was besisides myself for quite a while. I am rebuilding her. I have the technology to make her better, stronger, faster..GMAN, I didn't need to see those pictures. That's hard to look at.![]()
